Typhoon IR Receiver
Etharr
Typhoon IR Receiver
Post by Etharr »
IR Receiver of Typhoon is fully MCE RC6 comaptible? If it works with XBOX 360 Univeral Remote?
Is this receiver visible in Windows system as Microsoft eHome Infrared Transceiver?
Re: Typhoon IR Receiver
Hi Etharr,
Yes, the IR Receiver of the GX Typhoon is MCE RC6 compatible, works with XBOX 360 Univeral Remote and visible to Windows system but only a receiver (does not transmit).
I hope this helps.
NssOne
Post by NssOne »
Sorry, just bumping this since it would be rather unnecessary to start a new thread.
I got myself one of the xbox 360 universal remotes. I'm wondering how I can use this with my GX Typhoon for media controls or anything of the sort (running Windows 8.1). I'm kind of at a loss at figuring this one out.
EDIT: Kind of at less of a loss now since I found this article on the XMBC wiki. Now I just need to figure out how I can command my PC with it some more.
2nd EDIT: XBMC has an add-on that allows you to edit the registry to perform a command/keystroke in relation to the button.
On a side note: with the popularity of XBMC, I really think LCDStudio could do with an XBMC plugin (like what was done with the Media Portal mini display plugin). It would make more attractive to XBMC HTPC builders.
