Animation speed
dr21702
Animation speed
Post by dr21702 »
The protocol documentation for the animation file states it is plain text file with lines of milliseconds followed by filename. (Though the the example hexadecimal screen dump doesn't match the text below which has "2" before every filename).
I have a simple animation working with 2 images as follows:
However the animation timing doesn't coincide with milliseconds as using a value 1000 has the animated image changed every 20 seconds. Am or doing this right? Or is there a bug or documentation issue?
Re: Animation speed
You are correct, a specified time of 1000 results to 20 second interval.
And you are right, unfortunately the manual is missing information that each interval is 20ms.
I wonder if you have used GTT Designer?
https://www.matrixorbital.com/News/gtt- ... evelopment
You can use the GTT2.5 protocol animation object, as an alternative.
dr21702
Re: Animation speed
Post by dr21702 »
Raquel wrote:
Tue Dec 28, 2021 1:45 pm
Thank you for clarifying this.
