GLK240128-25 corrupted
gstlachi
Post by gstlachi »
The lcd is having a strange behaviour. It does not responding correctly to the MOGD# 1.1.5 application:
- When i try to send text or draw a graphic the displays show weird things, although, the MOGD# detects the display correctly. Mostly, every changes puts the lcd in high contrast
- I try to update the firmware v8.3 to v8.4, all the steps are well until an error appears = Error detecting bootloader.
I hope you can help me...
Thanks....
Regards.
Re: GLK240128-25 corrupted
I wonder, since the firmware upgrade did not complete (bootloader error), the display should remain at v8.3.
Can you please confirm this for me? Cycle the power on the unit and do an Auto Detect in mogd# please.
Once we are at a known state, we can hopefully figure out why commands do weird things, and why contrast becomes dark.
gstlachi
Post by gstlachi »
Raquel thanks for attend,
Yes, It detects correctly the lcd. The following data appears:
Speed : 19200
Display Type: GLK240128-25
Pcb Revision: 1.x
Yet, it has the same behaviour.
The revision printed in the lcd is R4.0. I guess the firmware still remains v8.3
Thanks again...
Tino
Post by Tino »
Can you tell me what commands you are sending to display to draw the graphics and send the text?
Once we know the commands we can further troubleshoot and diagnose the issue.
Martino
Martino DeLeon
gstlachi
Post by gstlachi »
I get an oscilloscope to debug the signals and this is what i have:
- TEXT:
MOGD# COMMAND DISPLAY
SET CURSOR x:4 y:4 FE4704 HIGH CONTRAST
CREAR SCREEN FE HIGH CONTRAST
SEND TEXT: A FE310100 FEAC00 HIGH CONTRAST
- GRAPHICS X1:10, X2:20, Y1:10, Y2:20 COLOR: BLACK
DRAW LINE FE63FF FE6C0A0A14 HIGH CONTRAST
DRAW RECT FE72FF0A0A14 HIGH CONTRAST
CONTINUE LINE FE63FF FE650A HIGH CONTRAST
- CONFIGURE DISPLAYS DEFAULTS
BACKLITE ON FE42 HIGH CONTRAST
BACKLITE OFF FE HIGH CONTRAST
CONTRAST FE5001 FE91 SOME VALUES ARE CORRECT
Any suggestions?
Thank you.
Regards.
Tino
Post by Tino »
When you first power up the display is the contrast high? or is it at the default?
Also is it possible that you use a different computer?
Martino
Martino DeLeon
gstlachi
Post by gstlachi »
Yes, I had to install the MODG# app in a different computer and it is working well :)
Thanks for help.
Regards
