GLK24064-25-IU Not Detecting COM Port after wipe
Dilipkumar
Post by Dilipkumar » Fri Dec 07, 2018 4:26 am
Hi All,
i used GLK24064-25-IU this with MOGD#1.1.8 after used wipe command i am not able use this device .Device was not detect & Error :Connot open comport
Regards,
Dilip
Re: GLK24064-25-IU Not Detecting COM Port after wipe
Post by Daniel Divino » Fri Dec 07, 2018 9:09 am
Hi Dilip,
Welcome to the forums!
I understand that you have a GLK24064-25-1U display, and after using MOGD to wipe the display, you are not able to detect the display again.
Could you tell me what PCB Revision you have?
Also, did any errors occur while you were wiping the display?
Dan
Dilipkumar
Post by Dilipkumar » Sun Dec 09, 2018 11:45 pm
Hi Dan,
Thank you for reply.There no errors on wipe process & PCB revision Board 1.0.
Post by Daniel Divino » Tue Dec 11, 2018 9:10 am
Hi Dilip,
Are you using a USB GLK24064R-25-1U display variant? Also, have you installed the proper USB drivers on the display?
Users browsing this forum: No registered users and 15 guests
