GX Typhoon WidgetPlugin SDK Creation Guide
Post by Daniel Divino » Wed Mar 29, 2017 12:10 pm
1) Open up vs.net and click New Project
2) Choose the language of your choice and create a new Class library project and call it MyWidget
3) Add a reference to CoreInterfaces.dll located in your lcdstudio folder.
4) Add a reference to System.Drawing.dll located in the .net tab of the add reference dialog.
5) Paste the following code into class1.cs (C# is used but this code is that basic it shoudn't be hard to convert to VB.Net)
Code:
using System;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Drawing.Text;
using LcdStudio.Base;
using LcdStudio.CoreInterfaces;
namespace MyWidget
   public class MyWidgetRenderer : AbstractWidget
      public override void Render()
         Graphics g = Graphics.FromImage(_Canvas);
         //Clear the drawing space
         g.Clear(CoreSettings.ColorOff);
         //Define some Drawing tools
         Pen p = new Pen(CoreSettings.ColorOn);
         Brush B = new SolidBrush(CoreSettings.ColorOn);
         //Draw our neat little square
         Rectangle R = new Rectangle(0,0,this.rect.Width-1,this.rect.Height-1);
         g.DrawRectangle(p,R);
         g.DrawLine(p, R.X, R.Y, R.Right,R.Bottom);
         g.DrawLine(p, R.X, R.Bottom, R.Right,R.Top);
         //If there is an data item set draw it
         if (LcdDataItem != null)
            //turn off aa and other text smoothing effects
            g.SmoothingMode = SmoothingMode.None;
            g.TextRenderingHint  = TextRenderingHint.SingleBitPerPixelGridFit;
            //Draw the text
            g.DrawString(LcdDataItem.Value.ToString(),new Font("Arial",12),B,0,0 );
         // Neatly dispose our gfx object
         g.Dispose();
      public override bool AcceptsData(LcdDataItem i)
         //our widget accepts any data you drop on it.
         return true;
   public class Plugin : AbstractPlugin
      public override void Initialize(System.Xml.XmlNode configNode)
         IToolboxView tbv = (IToolboxView)ServiceManager.GetService(typeof(IToolboxView));
         if (tbv!=null)
            // The perferd way to do this is ofcourse embed an icon into the dll but for
            // Simplicity reasons we'll just draw one our selves.
            Bitmap MyIcon = new Bitmap(32,32);
            Graphics G = Graphics.FromImage(MyIcon);
            G.Clear(Color.Purple);
            G.DrawString("HI",new Font("Arial",15),Brushes.GreenYellow,0,0);
            G.Dispose();
            // Add The icon to the Toolboxpanel
            int iMyIcon = tbv.AddIcon(MyIcon) ;
            //Add The Widget To the toolbox
            tbv.AddItem("MyWidgets","Square",iMyIcon,typeof(MyWidgetRenderer));
6) Create a file in your LcdStudio folder called MyWidget.Plugin with the following lines
<?xml version="1.0" encoding="utf-8" ?>
<Plugins>
   <Plugin ID="My Widget" Type="MyWidget.Plugin, MyWidget" Visible="Yes" >
      <Depends ID="ToolboxView" />
   </Plugin>
</Plugins>
7) Run LcdStudio and add your Plugin in the config panel & Restart the application
You'll find a how-to guide to creating DataPlugin SDK's here.
Users browsing this forum: Baidu [Spider] and 4 guests
