Questions about the GLK12232-25
rene
Post by rene »
Can the size of the GLK12232-25 be compared with the LK204-25? Could I squeeze the same amount of characters (or even more) as on the LK204-25?
The GLK12232-25 was made with the intent of being a direct replacement for alphanumeric 4x20 LCDs. Physically the LCD2041/LK204-25 are exactly same size as the GLK12232-25. And if you use the default font the GLK will act like a 4x20 LCD... :grin:
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-01-08 17:19 ]</font>
rene
Post by rene »
Thanks for your mega-fast reply! This is then the display I'll need!
by the way. Is the backlight shining with constant illumination, or can it be changed in any way (eg. 0 - 100%)?
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
http://www.icehardware.net/reviews/graphiclcd/
and only on/off through software (that I've seen) - though adding a variable resistor to be able to dim it by hand would be very easy :smile:
r.
p.s. With the small font you can get quite a few more chars on the screen - but the character lengths are not fixed so it varies depending on what you're displaying (i.e. you could fit a lot of i's on the screen and not many Z's).
Yes, the backlight is on or off...
