Reading Data from LK404-55 over I2C serial bus.
Thanks for the excellent example...!!! :D
RussCA
Post by RussCA »
Miles,
No problem, glad to help.
It would be nice to have a facility to share files here.
Russ
Russ
Have you tried Renewable Energy yet?
Interesting idea...Will have to look into that!! :D
RussCA
Post by RussCA »
There are a few problems in the I2C.C code posted earlier. Here is a corrected version.
Russ
 * Routines to drive a standard I2C bus.
#include <stdio.h>
#include "\JKMicro\H\i2c.h"
#include "\JKMicro\H\Ports186.h"
  #define SCL     PORTA
  #define SCLBIT  0x00
  #define SDA     PORTB
  #define SDABIT  0x00
 * I2C Routines derived from the pseudo code by V. Himpe,
 * and are likewise released into the Public Domain by:
 * Russell W. Ranshaw
 * For more information, visit:
 *  http://www.ping.be/~ping0751/i2cfaq/i2cindex.htm
 * I2Cinit is to be called immediately after power up.
 * This is normally the only I2C routine to be called
 * directly by the application.
void I2Cinit (void) {
	int n;
	I2Chighsda ();
	I2Clowscl ();
	for (n = 0; n < 3; n++) {
		I2Cstop ();
void I2Cstart (void) {
	I2Chighscl ();
	I2Chighsda ();
	I2Clowsda ();
	I2Clowscl ();
	I2Chighsda ();
void I2Cstop (void) {
	I2Clowsda ();
	I2Clowscl ();
	I2Chighsda ();
int I2Cgetbyte(void)
	int i_byte = 0, n;
	SetInputPort (SDA);
	for (n=0; n<8; n++)
		I2Chighscl();
		if (GetPortBit (SDA, SDABIT))
			i_byte = (i_byte << 1) | 0x01; /* msbit first */
		else
			i_byte = i_byte << 1;
		I2Clowscl();
	I2Chighsda ();
	return(i_byte);
void I2Cputbyte(int o_byte)
	int n;
	for(n=0; n<8; n++)
		if(o_byte&0x80)
			I2Chighsda();
		else
			I2Clowsda();
		I2Chighscl();
		I2Clowscl();
		o_byte = o_byte << 1;
	I2Chighsda();
void I2Cgiveack(void)
	I2Clowsda();
	I2Chighscl();
	I2Clowscl();
	I2Chighsda();
void I2Cgetack (void) {
	int n;
	I2Chighsda ();
	I2Chighscl ();
	SetInputPort (SDA);
	/* Wait until Slave pulls SDA low */
	/* Note:  The pseudocode does not have the for loop.
	 * It was added to prevent a lock up situation.
	 * Actually, there should be more error checking and reporting
	 * in this code.  For example, this routine should indicate a
	 * missed ACK.
	for (n = 0; n < 100; n--) {
		if (GetPortBit (SDA, SDABIT) == 0)
			break;
	I2Clowscl ();
	SetOutputPort (SDA);
void I2Chighsda(void)
	SetPortBit (SDA, SDABIT);
void I2Clowsda(void)
	ClearPortBit (SDA, SDABIT);
void I2Chighscl(void)
	SetOutputPort (SCL);
	SetPortBit (SCL, SCLBIT);
void I2Clowscl(void)
	ClearPortBit (SCL, SCLBIT);
 * Routine to send an address on the I2C bus.  To indicate
 * adr is a 10-bit address, set the high-order bit (0x8000).
void I2Csendadr (int adr, int rw) {
	I2Cstart ();
	if ((adr & 0x8000) != 0) {
		/* Send two MSBs of the ten bit address */
		I2Cputbyte (0xF0 | rw | ((adr > 8) & 0x06));
		I2Cgetack ();
		I2Cputbyte (adr & 0xFF);
	} else {
		I2Cputbyte (adr | rw);
	I2Cgetack ();
/* Read num bytes from device adr into buf */
void I2Cread (int adr, int num, char *buf) {
	I2Csendadr (adr, 1);
	while (num-- > 0) {
		*buf++ = I2Cgetbyte ();
		if (num > 0) I2Cgiveack ();
	I2Cstop ();
/* Write num bytes to device adr from buf */
void I2Cwrite (int adr, int num, char *buf) {
	I2Csendadr (adr, 0);
	while (num-- > 0) {
		I2Cputbyte (*buf++);
		I2Cgetack ();
	I2Cstop ();
Russ
