Not more colours... (!)
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
just to complete the spectrum I bought a very expensive LED... and damn it looks ugly :smile:
:sad: (The led is a little too bright, hence the halo effect being a little worse than normal)
r.
<font size=-1>[ This Message was edited by: TheCheeseMan on 2002-01-21 07:27 ]</font>
relix
Uber Slave
Uber Slave
Post by relix »
doesn't look so bad, I even like it! It would be cool on some places, anyway, you tried it, and now the world can see the MO LCD's in every color!
jodynicH
Case Guy
Case Guy
Post by jodynicH »
looks really nice, maybe one day here soon ill get the balls to do that to mine
No kidding!
Thlayli
Post by Thlayli »
Ok, I'm fairly new at this but I have a question about this fairly neat modification to your lcd:
Did you just replace the led backlight and thats it? If so, most of those LEDs require different voltages to work optimally, did you have to mess with any of the resistors?
Or am I way off base? Thanks!
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
The mod is all documented here http://www.icehardware.net/guides/col_lcd_mod/ - well kindof. You're right in worrying about the led voltages, though all the led's above are between 3.3V and 4V so it doesn't really matter. I used a small preset resistor so I could change it if I needed to and wired on a fan connector to plug the leds in quickly and easily...
Obviously when you've chosen a colour you can wire in a normal 5% resistor and solder the led in place.
r.
Thlayli
Post by Thlayli »
Ahh thanks for the link. Now if only my lcd panel would come. How I long for the day that teleporters are invented so I can get my latest toy instantly.
it usualy takes 1 day to ship in the states and canada and 2 days to europe... :smile:
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Finally got around to adding an update (with all the colours in a nice wavelength order) to my site - http://www.icehardware.net/guides/col_lcd_mod/update/
r.
Ces
Post by Ces »
is it possible to run these things inversed? black background over red font? thanks for any help
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Yes, just invert the font!
r.
