x64 MX212 -> File Not Found
- LCD!
I have downloaded the new drivers but everytime it tries to install it goes through everything and says "File Not Found" at the end. Doesn't tell me which file.
Running on a Asus K8V SE Deluxe, full build of Windows XP x64 edition.
Hi NecroDeemer,
Thank you for posting at the forums.
The system is looking for the file, you must specify where you saved the driver to. The following link is a guide on how to install the usb drivers.
http://www.lcdforums.com/forums/viewtopic.php?t=1032
I hope this helps you out.
If you have anymore questions, please feel free to post.
- LCD!
- LCD!
- LCD!
- LCD!
You downloaded the 64bit drivers from http://www.lcdforums.com/forums/viewtopic.php?t=1016 right?
- LCD!
yes, I did not know there were 64 bit drivers untill today, when I noticed the support bit of the MO website.
this is what I get:
http://www.necrodeemerdesigns.co.uk/fnf.jpg
this is what I get:
- LCD!
No change whatsoever.
I have attached a CPU-Z Output if that may be of any use
- cpuz.rar
- CPU-Z HTML Summary
- (1.36 KiB) Downloaded 405 times
Our problem is that we do not have a 64bit Windows to try the drivers on, and our testers said the driver was good.
Attached is the original driver files from the manufacturer. Uncompress them into a directory, and see if at anytime you can point windows there when it says there is a missing file.
- ftdi64_2154_mo.zip
- (107.61 KiB) Downloaded 310 times
- LCD!
