What is wrong?
dragons_fire
Post by dragons_fire »
I dont mean to take over this topic, but i have the same screen. its the LK-204-25-V, PCB version 1.23. i would like to convert it to ttl levels for use with a microcontroller. i noticed that Raquel said that trance_nation's board was set at ttl levels so i think it can be done... any help would be apreciated...
thanks
Danny
Hi Danny,
Here's a picture of what should be done:
trance_Nation
Post by trance_Nation »
now im here again, shall i solder thos things under de D-sub like pic 1 or pic 2?
First one, they should be verticle...
trance_Nation
Okay, hmm, its very dificult to solder these.
is it possible to unscrew the screws and split the teo plates and sold on the other side?
Hi
I guess you were talking about screwing/unscrewing the D-sub connector, sorry but you can't do that.
What I can suggest though is use small pieces of wire to bridge the gaps. Wire wrap wires work good for these kinds of reconnection of broken traces on the PCB.
trance_Nation
no i meant unscrewing the screws for the two plates so i can solder on the other side of the dsub because it was easyer to do that there. and so i did, now it work perfectly thx guys! :)
