GX no text but has backlight
got this new GX tricolor today.
I followed the soft install procedure
Backlight is on
Text or welcome screen not visible
Device manager in XP shows device code error (10)
Also device manager shows as error in "composite device" list like a red circle
I tried select manual install options, says driver cannot be found in MO driver dir.
I tried manual install and selected USB composite device in windows dir, no go
I tried new install, no go
Am I doing it wrong ?
regards,
Adrian
Backlight is on
regards,
Adrian
Hi Adrian,
The drivercore install will hold the drivers required for your GX, when complete they'll be saved in the Matrix Orbital DriverCore\Drivers folder. As you can see, there isn't much to the installation, if you follow the instructions step by step.
If you are having trouble, try uninstalling DriverCore, unplugging your display, reinstalling DriverCore, and then plugging the unit back in. Also, if you can, try to troubleshoot with a different cable and/or computer.
If the GX configuration utility can see the display at all, and try changing the contrast if it is somehow too low. Should you continue to have trouble, let us know what the effects are of the above.
Hi Troy,
just to confirm are all the headers without jumpers ?
I'm thinking maybe a jumper link fell off one of the pins
Tried 2 more pc's, no go
3 cables test OK
um, windows detects no prob, but composite device has a yellow ! in device manager and error code :
MICROSOFT says:
If a device is unknown (usually because of missing drivers), the device has a yellow question mark next to it.
"cannot start device code (10)"
Here's whats in the drivers folder files: path(C:/program files/MO DriveCore/drivers)
gx_fwu.cat
gx_fwu.inf
gx_irbus.inf
gx_lcd.cat
gx_lcd.inf
gx2_lcd.cat
gx2_lcd.inf
WdfColnstaller01007.dll
WinUSBCoInstaller.dll
9 files total
I'm a little bit competent with electronics, is there any voltages I can test for or check data signals
I'm thinking if I could pull it apart, measure to see what components may be faulty ????
GX managment console :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: s
at System.IO.StringReader..ctor(String s)
at System.Xml.XmlDocument.LoadXml(String xml)
at DriverCoreTray.XmlConfigPanel..ctor(String xml)
at DriverCoreTray.MainGui.ConfigureLoadedDriver_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
DriverCoreTray
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Matrix%20Orbital%20DriverCore/DriverCoreTray.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
LibDriverCoreClient
CodeBase: file:///C:/Program%20Files/Matrix%20Orbital%20DriverCore/LibDriverCoreClient.DLL
log4net
Assembly Version: 1.2.10.0
Win32 Version: 1.2.10.0
CodeBase: file:///C:/Program%20Files/Matrix%20Orbital%20DriverCore/log4net.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
LibGX2
CodeBase: file:///C:/Program%20Files/Matrix%20Orbital%20DriverCore/LibGX2.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
regards,
Adrian
3 cables test OK
MICROSOFT says:
gx_fwu.cat
gx_fwu.inf
gx_irbus.inf
gx_lcd.cat
gx_lcd.inf
gx2_lcd.cat
gx2_lcd.inf
9 files total
Parameter name: s
mscorlib
DriverCoreTray
System
System.Drawing
LibDriverCoreClient
log4net
System.Xml
LibGX2
enabled.
For example:
<configuration>
</configuration>
regards,
Adrian
Hi fellas,
I sent you PM (Ray & Troy), a short vid, and jpgs
please let me know you got them
regards,
Adrian
regards,
Adrian
- Graphic_10_5_2010 1_20_53 PM.jpg (21.81 KiB) Viewed 25181 times
- Graphic_10_5_2010 1_20_48 PM.jpg (45.09 KiB) Viewed 25181 times
- Graphic_10_5_2010 1_21_09 PM.jpg (35.37 KiB) Viewed 25181 times
Just now added a youtube
the link is private
the link is private
oh dear, I was so hoping for that not to happen. bugger.
Thanks very much for helping with this.
the other 2 screens are fine though..
Howdy,
Thanks very much for the replacement
Arrived very quickly, thanks a lot
Wow, pretty colors, Works beautifully, especially of note how the colors can be changed using the slider bars, yipeeeee
(I'll dig around the other display see whats up) I cant believe how much work has been put into your Displays, excellent work there.
Thanks again for all the help
regards,
Adrian
regards,
Adrian
No worries Adrian, good to see the unit arrived safe and sound. Enjoy the colour benefits of your new GX, feel free to post up your favorite designs/pics, and don't be a stranger if you have any further questions or concerns as you continue your build.
