Hello!!
I am getting a issue while clicking multiple time on same region. I got some garbage/squares printed on screen. seems some buffer issue.. I am having separate buffer index for separate region and issue comes only when I keep pressing multiple times.
please help me regarding this and tell me possible solution.
Ashok
Multiple Click Issue
Ashok Gupta
Hi Ashok,
I've run a few different variations of the attached code, but am unable to cause any extra characters to show on the screen. The boxes could be parts of other commands that have not executed properly. I am running firmware R1.1.0.3081.
Try the code below in the GTT Tools program and let me know if you have any trouble. If you can modify it to cause the error you noted, please post it so we can take a look here.
- Touch Test.gsf
- Two region touch test attempt to cause erroneous characters to display on the screen.
- (297 Bytes) Downloaded 658 times
