java/ gpo/fan control
chiefgenius
Post by chiefgenius »
ive got a couple of questions. first, is the LK204-25PC Limited edition the only lcd that you could hook a fan up to? second, is it possible to write a java program to control these fans, which would also get input from a temperature sensor
yes and no. All lcd with GPOs can do it, but the LK204-25-PC is the only one that you do not need to add a transistor, mosfet or relay to to make it work.
I just uploaded a java programing example... no one has done full software for it yet though.
http://www.matrixorbital.com/faq/ex3.htm
chiefgenius
i looked at that example, but it only shows how to code using the keypad inputs. I need to know how to i can control the gpos from the program. if thats too difficult or time consuming, i remember seeing a pascal thing on this site somewhere, so is it possible to write a pascal program to control the gpos?
ive looked at the fan program you had, and im going to make one that in effect does the same thing, put to make it interesting im going to use a fuzzy controller to keep my computer in an acceptable range
chiefgenius
let me try to fix what i just tried to say: I want to write a program in java or pascal which only has to be able to turn on and off the gpos, and display a message like "GPO 1 shut off" or "GPO 1 turned on". thanks for any help
chiefgenius
help, anyone?
It's simple, you take that little piece of Java and add in the GPO commands.
chiefgenius
i must be dumb or something, but i see in the code how you can change messages on it, but i have no idea of how you control the power to the gpo, is that in there somewhere, or do i have to figure that out myself
Well, there is a number of commands in the code, all you have to do is add more.
chiefgenius
im sorry, i shoulda read the manual first. it shows everything i needed to know. btw, i just ordered a LK204-25PC, which is gonna look so sweet in my box
well, we all expect pictures :smile:
enjoy!
chiefgenius
well, i posted that as i was ordering, but now it didnt work for me, im gonna restart the whole process
chiefgenius
phew, ok, now it worked, i hope i didnt get billed twice though, even though i never hit purchase the first time. it did remember the user id though, thats the only reason i would think that. i bet the problems on my end, pos aol(its not my fault im using aol, its my parents, please dont exile me)
