Eksigent
Website: http://www.eksigent.com
Display Used: GLK19264-7T-WB
Features: The cHiPLC-nanoflex system is a docking station for up to three microfluidic chips. The system's flexible design and built-in 10-port nano valve allow for easy switching between different types of experiments such as direct injection and trap-loading.
- GLK19264-7T-WB Eksigent
- eksigent.JPG (16.01 KiB) Viewed 112566 times
Dispense Works
Website: http://www.dispenseworks.com
Display Used: LK204-25-GW-VPT
Features: The Dispense Works robot is optimized for industrial dispensing applications of virtually any type of material.
- 3653 Pulse.JPG (40.78 KiB) Viewed 112562 times
Citrix Systems
- LK162-12-WB
- landing_accessgateway.jpg (28.02 KiB) Viewed 112141 times
Gigawave Microwave Technology
Website: http://www.gigawave.co.uk
Display Used: GLK19264-7T-1U-WB
Features: The RMD-HD is a stand-alone ASI decoder for SD/HD MPEG2 digital video. The unit accepts ASI DVB transport stream at the input, decodes the signal according to MPEG2 profiles, and outputs one video plus the associated audios.
The RMD-HD occupies 1U rack mount space and powers from 110/230VAC.
The unit is compatible with Gigawave digital link receivers when operated in the ASI mode. The RMD-HD, for example, may be used as an add-on box to decode HD wireless camera transmitters using an SD capable digital link receiver.
- GLK19264-7T-1U-WB
- gigawave_1.jpg (34.19 KiB) Viewed 112148 times
Infineta Systems
Website: http://www.infineta.com
Display Used: GLK19264-7T-1U-FGW
Features: The Data Mobility Switch (DMS) is the industry’s first Hyper-scale WAN Optimization solution. The DMS provides instant 5-10x bandwidth capacity gains, IP traffic acceleration, and critical application prioritization for inter-data center workflows such as replication, long distance ‘live’ migrations, massive file transfers and Big Data.
- GLK19264-7T-1U-FGW
- DMS_front_top.jpg (37.33 KiB) Viewed 112145 times
XEI Scientific Inc.
Website: http://www.evactron.com
Display Used: VK204-25
XEI Scientific, Inc. manufactures the Evactron De-Contaminator, a compact remote plasma cleaning device which can remove hydrocarbon contamination from vacuum chambers such as scanning electron microscopes (SEMs). XEI Scientific also manufactures a plasma cleaner which can be inserted in a transmission electron microscope (TEM) and a low power 13.56 MHz RF generator.
Datacom Systems Inc.
Website: http://www.datacomsystems.com
Display Used: GLK19264-7T-1U-WB-LV
Features: Data Capture Infrastructure Optimizes Network Monitoring and Increases Efficiency
Networks are growing more complex, carrying more services, higher volumes of multi-protocol network traffic, and requiring greater bandwidth. At the same time, network and security personnel are required to monitor and analyze more links in greater detail throughout the network in order to meet application performance demands, minimize security threats, and meet regulatory compliance. Higher speed networks are being deployed, fueling the need for higher speed monitoring tools. However, while networks are getting faster, many network and security professionals are also having to make do with the legacy monitoring tools they already have.
- ss-2212-front-copy.jpg (18.65 KiB) Viewed 108400 times
- GLK19264-7T-1U-WB-LV, SS-2212-10G
- SS-2212-10G.jpg (24.26 KiB) Viewed 112112 times
- GLK19264-7T-1U-WB-LV, VS-1212-F
- VS-1212-F.jpg (21.95 KiB) Viewed 112114 times
Aeroqual
Website: http://www.aeroqual.com
Display Used: LCD2041-WB
Features:The Aeroqual UV-H Photometer Instrument is designed for measurement of ozone in the range of 0-200 ppm using a single beam UV photometer. It is housed in a portable instrument case and is designed to be used in a variety of ozone measurement applications. The UV-H ozone photometer is a high performance yet cost effective monitor with full data logging functionality. Data is logged to a removable Secure Digital (SD) card or logged directly to a PC
using the supplied software. Optional analog and relay control outputs are available for control applications.
- Aeroqual, LCD2041-WB, IQM-60
- Aeroqual-IQM-60.jpg (35.73 KiB) Viewed 112105 times
- Aeroqual-UV-H.jpg (34.44 KiB) Viewed 112107 times
Resodyn Corporation
Website: http://www.resodynmixers.com
Display Used: LK202-25-WB
Features: The LabRAM is a lab mixer that thoroughly mixes gases, liquids, solids, powders and very viscous compounds with a nominal capacity of 1-pint. A variety of mixing vessels may be used including small vials and disposable plastic containers and bags. Mixing versatility, quick sample turn around, and the ability to safely mix sterile or hazardous materials, make the LabRAM an indispensable mixer for any laboratory or small-scale production process.
- LK202-25-WB, LabRAM, Resodyn
- rasodyn_LabRAM_Mixer.JPG (27.87 KiB) Viewed 112048 times
Aqua Metrology Systems Limited
Website: http://www.aquametrologysystems.com
Display Used: LK204-25-USB-WB
Features: The THM-100, the Company’s first product, monitors trihalomethanes (THMs) in potable water, known carcinogens that affect liver and kidney functions through repeated exposure. THMs are also suspected of affecting gestation in pregnant women.
THMs are generated in the water production process when organic material in raw source water combines with chlorine or bromine used in the disinfection process. Governments set limits on the amount permissible in drinking water, and THM levels can be managed by using additives, such as coagulants and activated carbon products which bind and remove the organic material prior to the addition of chlorine; by blending sources of water low in THMs; and by managing the dosage of chlorine used in disinfection.
- THM-100, LK204-25-USB-WB, Aqua Metrology Systems Limited
- THM-100.jpg (105.49 KiB) Viewed 112037 times
ITSMAX
- GLK240128-25-WB-VPT-E
- tour perception.JPG (25.42 KiB) Viewed 110382 times
Belquette Inc.
- LK202-25-USB
- Mod_Top.png (300.58 KiB) Viewed 110381 times
- LK202-25-USB
- Flexi_Top.png (178.11 KiB) Viewed 110381 times
SpectraSensors
- LK204-25-E
- SS3000_rotator.jpg (44.74 KiB) Viewed 109158 times
- LK204-25-E
- instrument_01.png (47.79 KiB) Viewed 109158 times
DowKey Microware
- _plk185_1_CBSeriesfrontviews.jpg (76.5 KiB) Viewed 109156 times
