Typhoon LCD and USB hub
irish56_ak
Post by irish56_ak »
I am building a PC and have a Typhoon LCD to install. I also have a NZXT internal USB Expander. The expander plugs into a standard USB 2 motherboard header and also has a power connector for the power supply. It is plug and play and requires no drivers. OS is Windows 7 64 bit. The expander will be supporting a Bluetooth dongle and wireless mouse receiver. Does anyone know if the Typhoon will operate correctly attached to the expander or does it require a dedicated USB port.
Yes, the GX Typhoon should work on the USB Expander.
Best regards,
