Bezel and OK204-25
luis.taboada
Bezel and OK204-25
Post by luis.taboada »
Hi, It seems that the Bezel 4x20 won't fit the OK204-25, I follow the instructions but the 3/8'' screws won't pass thru, any help? thanks.
Re: Bezel and OK204-25
Hi Luis,
Welcome to the forums!
I understand you are having difficulties mounting your OK204-25 display on your 4 x 20 Bezel. Just to clarify the issue, do the 3/8" screws fit through the PCB mounting holes?
When test mounting the display, do all 4 screws align properly with the bezel?
Hi Luis,
After further investigation, we have confirmed the issues that you have experienced with the provided screws not fitting in the OLED's mounting holes. The issue is due to the OLED display's mounting holes being 2.5mm in diameter, which is too small for the recommend 5/8" screws.
At the moment, we will be removing the OK204-25 and it's -USB variant from the BEZ-204A-V1 compatibility list until we have a solution to the problem.
We would like to right our wrong in this case and compensate you for the troubles and the inconvenience this has caused you. I will PM you to discuss what compensation would work best for your current situation.
I apologize for the inconvenience.
luis.taboada
Thanks for the reply, I made some changes to the bezel, it was already glued to the cabinet :(
But the final work has no problems.
Hi Luis,
I'm glad to see you were able to resolve the issue in the end.
The bezel looks really good from what I can see!
