I have a GTT38A, which I'm able to use and communicate with fine.
I have an application where the GTT38A is a few feet away from the hardware talking to it, via RS232. In the event of a communication loss, I need to be able to do a hard reset. I'd rather not have to do something to cycle the power to the GTT38A. I can't use gtt25_gttmodule_reset() because ... there's a communication loss.
I was hoping the GTT38A would respond to a BREAK and reset, I tried that (sent it a 2 second BREAK) but there was no effect.
I looked in the hardware manual, but there is no "reset" pin on any of the module interface connectors.
Is there any hard reset solution available, other than cycling the power?
Regards,
Adrian
GTT38A hard reset?
Re: GTT38A hard reset?
Hi Adrian,
Welcome to the forums! I'm glad to hear you are working with our GTT.
Unfortunately, there is no way to hardware reset the display other than applying a power cycle.
We have implemented a few measures to reduce the chance of a communication loss, such as hardware flow control, and a secure packet transfer protocol, but hardware wise a power cycle is the only option available.
Thanks Daniel,
You might care to consider this for a future firmware release.
A command to enable BREAK recognition (default would be off, so operation as it is today).
If it has been enabled, a BREAK for a certain minimum time would cause a hard reset.
Regards,
Adrian
Regards,
Adrian
