EVE Asset Builder (EAB) 2.11.0
Release Notes Version 2.11.0
Link:
https://www.matrixorbital.com/index.php ... t&did=1820
Feature Updates
ASTC Encoder
• Users can now select any version of astcenc for improved flexibility.
• The ASTC encoder has been updated to version 4.x.
• Added an ASTC Encoder link in the Info tab for quick access.
Font Converter
• The output file _charmap.txt has been removed for a cleaner output.
Flash Utilities
• A separate option for BT817A has been added for better usability.
• Added subtype for animation to enhance animation support.
Animation Converter
• Reversed the arrangement of .data and .object for user convenience.
• Removed the .anim file from the output folder.
Bin2C
• Aligned the converted value to the left for improved readability.
Image Converter
• Improved the generated SampleApp for DXT1 bitmap generation.
Custom Touch Compiler
• Added a new compiler for BT88X/FT81X.
• Included new macros and pseudo code in the Read Me tab.
Installer
• The setup file is now signed with a company certificate.
Resolved Issues
Animation Converter
• Resolved the issue associated with 2-frame GIF input.
• Addressed the bug that occurs when disabling the Tile Size.
Flash Programmer
• Corrected the text argument of Eve chip generation.
Font Converter
• Fixed the bug related to the wrong baseline in Font Converter.
Sample App
• Resolved the issue of excessive restore_context() command.
Image Utilities
• The layout of the Input File is no longer cut at the top.
