External install ideas
well, you dont have to give up two of your main drive bays, depending on what case you have....
check out this article on how i mounted the display in my lian-li pc 68
http://www.blagged-hardware.net/content ... ntrol.html
this is my external install ![:smile:](./images/smilies/icon_smile.gif)
Some of you might have seen this on bit-tech but for those of you who havn't here it is .
Here's my LCD and stand, as you can see it is a twist on the 55p photo frame
thanks for letting me use your logos bit-tech and MO, a nice little advert for ya
i created the photo in photoshop and printed it out photo quality.
looks nice![:grin:](./images/smilies/icon_biggrin.gif)
on this one you can see the various GPO's
also the mounting bolts and nuts are made for radio controlled cars but hey they fit
they are:
Schumacher Speed Pack U1546H M3 Caphead Bolts x2
Schumacher Speed Pack U1547I M3 Nuts x1
Schumacher Speed Pack U1548J M3 Nylon Washers x1
please tell us what you think![:smile:](./images/smilies/icon_smile.gif)
Working on a completly different way of mounting my 2nd LCD for my Lian-Li
Watch This Space
Later
AW3K
![Image](http://www.a-whiteman.pwp.blueyonder.co.uk/files/pages/lcd/images/03_lcd_stand.jpg)
looks nice
![Image](http://www.a-whiteman.pwp.blueyonder.co.uk/files/pages/lcd/images/02_lcd_stand.jpg)
they are:
Later
AW3K
I have an external display with buttons. The same cable also carries power. See here for details:-
http://mysite.freeserve.com/winamp_remote
Babber
Babber
Nice Job, Blabber! I am planning on something similar, but am also trying to have to option of running the GPOs back into the case through the same single wire (DB-25 I think). My question is why did you opt to use the Power/I2C connector when you could have powered the unit right through the DB-9? You still could have put a switch inline, right?
I chose to power the display through the 3 pin header as, if memory serves correctly, you have to solder a jumper on the pcb. I'd rather not do that. Using the supplied power pins made more sense. I dont use the GPOs so I cant comment on that. Ideally, i should have used a switch that isolates both + and ground lines.
Babber
Babber
BTW, in the US, WalMart has these $2 8x10" picture frames with black plastic frames and glass inserts that have ground edges. I haven't found the best way to cut through the glass yet, so I went out and bought some pre-cut 8x10" plexiglass at Home Depot (hardware store) and it fits in perfectly! Time to make the external mounts...
Looks like a custom holder/stand may be necessary depending on how you want to disply it.
---------------<br>
WhyPush<br>
WhyPush.com
WhyPush<br>
WhyPush.com
When you say its precut is it flat or put togehter so I can just slide my Lcd right in there?WhyPush wrote:BTW, in the US, WalMart has these $2 8x10" picture frames with black plastic frames and glass inserts that have ground edges. I haven't found the best way to cut through the glass yet, so I went out and bought some pre-cut 8x10" plexiglass at Home Depot (hardware store) and it fits in perfectly! Time to make the external mounts...Looks like a custom holder/stand may be necessary depending on how you want to disply it.
