I've had constant hassle with this device, although it works 70% of the time, the rest of the time the display freezes with corruption or doesn't work. My fix is reload firmware or shutdown system switch of at mains and press power button on pc, drain residual charge, the switch on.
Another effect of this failure is power to the fans. if it has one of its fits none of the fans will powerup. All drivers are installed and showing properly under Ports and USB.
I thought that the unit was very sensitive but now I'm beginning to think I shouldn't have to do this all the time !!!
I can understand your frustration and desire to have a perfectly working product. Unfortunately I cannot explain what is happening to your unit, however if you would like to discuss the situation further feel free to contact me at myero@matrixorbital.ca and we'll do our best to resolve the problem.
I know this topic is pretty old but i need the 2 files mentioned on the 1st page as my display is corrupted again and they give me a 404, can you tell me where i can find them?
