More On Cables
RalfRP
Post by RalfRP »
I was reading the other "cable hookup" thread and thinking (ouch, that hurts!) that maybe a neat wiring job is simpler than I thought.
I'm going to buy the BVF2041-BK (Real Soon Now!); in its pictures I don't see a DB9 connector on the back, but I'm sort of assuming it comes with one: pictures of other models show a female (F) DB9.
So the MO connecting cable is a M<->F DB9 cable, and I think I have some old slot covers left over from my misspent AT case days that have a DB9 cutout. So I put the other end of the connecting cable in the slot cover, and use those old screw-in "standoffs" (the tall hex-shaped things), then I have a nice slot cover with a F connector on it. Since the ATX mobo has a M DB9, all I need is a short M<->F jumper and I'm all set. Yes? This sounds reasonable and neat, right?
The question is, what about the jumper cable? It'd need to be short; the cable MO sells in a 1' length would work, but is a little long and ribbony. I'm thinking shorter and rounder...
Does all (or any :grin:) of this make sense?
PS: sorry for all the disturbing s*x talk :wink:
linear
evil Dr. linear
evil Dr. linear
Post by linear »
Works for me. the cable's really not that long. And a lot of cases have knockouts where you can mount it without wasting a slot cover.
RalfRP
Post by RalfRP »
Thanks linear... esp for draggin' out the camera for me... looks good.
Did you buy the bay kit? I wonder if it comes with the 1' or 4' cable (for the inside)...
any normal PC Bay insert comes with a 4ft, the -4BR comes with 1ft.
RalfRP
Post by RalfRP »
Thanks Henry! Do you recommed an additional 1' for an "outside jumper" or do you perhaps have even shorter cables?
Now I gotta order it :grin: and go find an old AT serial cover (or, as linear said, check my case for DB9-shaped knockouts - I forgot those even existed...)
Thanks to all...
linear
evil Dr. linear
evil Dr. linear
Post by linear »
heh, thanks for not asking why I have a paperclip jammed into my TV input on my vidcard....
it's a long story....
ok, you have my attention now, why is there a paper clip jammed into the TV input?
The shortest we have are 1 footers here. We use the 1ft jumper with the 4BR system close to what you are saying...
linear
evil Dr. linear
evil Dr. linear
Post by linear »
I don't have cable ~sniff~, and I'm too slack to buy a decent antenna, so it's my antenna. How ghetto is that?
.... let me put it this way.. HAHAHAHAHAHAHAHAHAHAHAHAAHAH... :grin:
how well does it work though?
linear
evil Dr. linear
evil Dr. linear
Post by linear »
It works about as well as you'd expect, but better than no paperclip.
Meanwhile, back on topic....
You can get IDC (insulation displacement connectors) D-sub connectors for ribbon cables here: [url=http://]9-pin plug[/url] 9-pin socket and roll your own. Want an IDC socket (to fit your mobo's pin headers)? they're here: 10-pin socket.
As far as ribbon cable, I can't help but imagine you could scrounge a used floppy cable or IDE cable for the project, but if you feel the need to spend, here's ribbon cable: right here.
None of that sex talk here....
