A Gallery of pictures...
I4P
Unit: GLK24064R-25-1U-FGW
Company: I4P
Website: https://www.i4p.com
TRIDENT HSM is the first hardware security module (HSM) in the world to combine high-level hardware security and multi-party computation in order to provide the highest level of data protection required in business.
1U LCD, Server Display, Serial LCD, Embedded Display, 240x64
1U Graphic LCD
1U Graphic LCD
Serial Graphic LCD
Serial Graphic LCD
Finna Group
Unit: LK204-25-E
Company: Finna Group
Website: https://www.finnagroup.com
LK204-25, Serial Keypad LCD
LK204-25, Serial Industrial LCD, IP65 LCD
Intrinsic Quality
Unit: LK162A-4T
Company: Intrinsic Quality
Website: https://intrinsicquality.com
Q’s Prodigy is designed to revolutionize programming for low volume high mix manufacturing with a cost effective and highly adaptable ISP microcontroller flash programmer. Based on SMH’s FlashRunner FR01ENG, Prodigy is brilliantly designed with a small footprint and a broad range of capabilities:
LK162A-7T, Small LCD, keypad LCD, Serial LCD
VivaBioCell S.p.A.
Unit: HTT70G-TPC-BLM-B0-H6-CH-V5
Company: VivaBioCell S.p.A.
Website: https://www.vivabiocell.it
Brew Bomb
Unit: EVE3x-43A-TPR
Company: Brew Bomb
Website: https://www.brewbomb.com
EVE3x-43A, EVE3, SPI TFT
Tuttnauer
Unit: HTT50G
Company: Tuttnauer
Website: https://www.tuttnauer.com
The Fully Automatic Sterilization Autoclave. Designed for Dental Clinics and Small Medical Practices
HTT50G 5"HDMI TFT with Capacitive touch screen
DG Technologies
Unit: GLK19264-7T-1U-WB
Company: DG Technologies
Website: https://www.dgtech.com
End of Line testing, ECU prototyping, data logging, bus analysis, simulation, validation, diagnostics, reprogramming and more!
1U LCD HMI, GLK19264-7T-1U-WB
Esprofesso
Unit: HTT70G
Company: Esprofesso
Website: https://esprofesso.com
7.0" HDMI Display
7.0" HDMI Display
HTT70G Industrial TFT
HDMI 7" TFT
HDMI 7" TFT
Total Scale Service
Unit: HTT101G
Company: Total Scale Service
Website: https://totalscale.com/
10.1" HDMI outdoor display
10.1" HDMI display with bezel
ELCo Enterprises
Unit: EVE3-35G-IPS
Unit: EVE3-50G-IPS
Company: ELCo Enterprises / Wire Wizard
Website: http://www.wire-wizard.com
The Gas Tracker™ Digital Gas Flow Monitor provides an easy way to monitor and track shielding gas flow in robotic or semi-automatic MIG or TIG welding applications. The Gas Tracker™ is two monitors in one – it may be used as a portable unit or mounted in-line. Provides a simple and accurate method for monitoring & totalizing incoming gas flow, or measurement and verification of gas flow at the nozzle.
3.5" SPI TFT, EVE3-35G-IPS
The Weld Central® is a Process Optimization System that monitors and tracks key (time-stamped) process variables, including current, voltage, wire feed speed, gas flow & feed motor current. This information can be utilized for both process optimization and determining the weld cell OEE (Overall Equipment Effectiveness)
5.0" SPI TFT, EVE3-50G-IPS
SIGMAPHI
Company: SIGMAPHI
Website: https://www.sigmaphi.fr
Orton Ceramic Foundation
Unit: LK202-25 20x2 Serial LCD
Unit: KPP202A 7 Button Keypad
Company: Orton Ceramic Foundation
Website: https://www.ortonceramic.com/
A Serial 20x2 Sunlight Readable LCD, with a 7 key keypad for a simple machine HMI.
LumaCyte
Unit: LK162-12-R-USB
Company: LumaCyte
Website: https://www.lumacyte.com
16x2 USB LCD
16x2 USB LCD
iesy
Unit: GLK19264-7T-1U-FGW 1U Graphic Serial LCD
Company: iesy
Website: https://iesy.com
1U Graphic USB LCD
1U Graphic USB LCD
Antelope Camera Systems
Unit: EVE2-38G 1U TFT Sunlight Readable
Unit: EVE3-43G 480x272 SPI TFT
Unit: EVE3-50G 800x480 SPI TFT
Company: Antelope Camera Systems
Website: http://antelope-cs.com
EVE2-38G 1U Bar TFT
EVE2-38G 1U Bar TFT
EVE3-43G Capacitive 4.3" Touch SPI TFT
EVE3-50G Capacitive 5" Touch SPI TFT
