Unit: MX212 (LK202-24-USB)
Company: uNav Microelectronics
Funtion: Data acquisition instrument used in R&D work. It captures raw digital data from RF-front end of GPS receiver to hard disk. This will "record" GPS signal and play it back later.There are two versions of this device, a portable version for field use and larger version for desktop use.
Website: http://www.unav-micro.com
- unav_576b.jpg (36.81 KiB) Viewed 72543 times
- unav2_820b.jpg (44.93 KiB) Viewed 72542 times
Unit: MX212 (LK202-24-USB-WB)
Company: Tyrrell Systems
Funtion: The "Communicator" integrates many systems within a building (lighting, heating, security, access control etc) and gathers the data together to present a common interface for control and monitoring purposes.
Website: http://www.tyrrellsystems.com
Brouchure The Communicator
- communicator.jpg (72.02 KiB) Viewed 72537 times
- exhib_board.jpg (71.01 KiB) Viewed 72538 times
C-COM Satellite Systems
Website: http://www.c-comsat.com
Unit: LK202-25-WB
Company: C-Com iNetVu
Funtion: The iNetVu is a unique auto-acquiring satellite antenna that allows the delivery of high-speed satellite-based Internet services into vehicles. With the push of a button, the iNetVu automatically deploys and finds the satellite signal in less than five minutes, allowing for access to VoIP, video, and a multitiude of other services from the Internet. With the iNetVu mobile antenna, one can perform instant communications from anywhere on the planet. There are over 1000 iNetVu's currently in use on every continent on the globe.
Unit: LK202-25-WB
- 9000 Front.jpg (13.46 KiB) Viewed 69456 times
- Rock hill 4.JPG (71.96 KiB) Viewed 72377 times
Pathway Connectivity Inc.
Website:
http://www.pathwayconnect.com/
Display Used: MOP-GL12232B-BGFW
Pathway Connectivity is the leading data communications company in the entertainment lighting industry. The largest and senior company in the business, Pathway has been defining the future of lighting network functionality for more than a decade.
- Pathport - C series
- pathportc.jpg (44.56 KiB) Viewed 70546 times
- Pathport R-series
- pathportr.jpg (33.29 KiB) Viewed 70546 times
MCR Technologies
- Weigh-Shark-new.jpg (21.78 KiB) Viewed 63984 times
- weighshark-lrg.jpg (14.42 KiB) Viewed 70543 times
- Weigh-Shark-rev.jpg (18.7 KiB) Viewed 70543 times
Surfx Technologies
Website: http://surfxtechnologies.com
Display Used: LK204-25-GW
Features: The Atomflo is a variable-chemistry plasma system, so you can tailor the plasma chemistry to meet your needs by simply feeding different reactive gases to the system. You can easily create a oxygen, nitrogen, hydrogen, or fluorine plasma, all with the same plasma controller! The unit can be set up in 10 minutes, and operation is simple and trouble-free. This versatile plasma controller will work with our entire lineup of plasma sources listed below.
- Atomflo 300 Plasma Controller
- atomflo_300.jpg (13.09 KiB) Viewed 69433 times
Canam Technology
Website: http://canam-technology.com
Display Used: LK202-25
Features: MARK-IV Digital Narrowband Signal Boosters. With Programmable Filters Bandwidth, Selectivity & Group Delay. Available for 800 & 700 MHz SMR bands, UHF, TETRA and VHF bands
- MARK-IV Digital Narrowband Signal Boosters
- canam1.jpg (49.46 KiB) Viewed 69529 times
EMS Ltd
Website: http://www.ems-uk.com
Display Used: LK202-24-USB-WB
Features: i-MO is an all inclusive managed service that is designed to accommodate the needs of organisations with many remote, temporary or semi-permanent user groups. It comprises high speed LAN-to-LAN communications, network security, IP optimisation and automatic seamless bearer roaming. All provided in a single low cost per month package.
- emsuk1.jpg (27.01 KiB) Viewed 69527 times
Lantronix
Website: http://www.lantronix.com
Display Used: LK202-25-WB-V
Features: The SecureLinx Branch Office Manager (SLB) enables administrators to securely manage remote servers and IT infrastructure equipment over the Internet.
- SecureLinx
- lantronix1.jpg (10.87 KiB) Viewed 69524 times
Decision Biomarkers
Website: http://decisionbiomarkers.com
Display Used: LK202-25-GW
Features: AVANTRAQ400 biomarker workstation allows biotech and pharmaceutical companies to test up to 20 biomarkers at one time. The system analyzes serum or plasma samples
- AVANTRAQ400 biomarker workstation
- avantras.jpg (58.82 KiB) Viewed 69519 times
iBall Instruments
Website: http://www.iballinstruments.com
Display Used: MOP-GL24064A-BGFW-22N-3IN
Features: iBall Instruments technology provides waterfall charts of gas units, hydrogen Sulphide, O2, CO2 and chromatograph readings via the Internet anywhere in the world.
- iball1.jpg (30.94 KiB) Viewed 69514 times
- iball2.jpg (15.22 KiB) Viewed 69514 times
