Software FAQ!!!
Derelique
Plugins
Post by Derelique »
Another question....can I use plugins that I see at LCDC website with LCD smartie? Or they are not compatible??
any opinions express by myself is entirely my own and it doesn't mean everyone has to agree with it.
PilchY
Post by PilchY »
got my hnads on a LK202-24-USB - WB and i need to get a copy of the drivers to install the equipment so that LCD smartie can pick it up... anyone help me?
Re: Plugins
Derelique wrote:Another question....can I use plugins that I see at LCDC website with LCD smartie? Or they are not compatible??
Hi Derelique,
No, LCDC plugins will not work with LCD Smartie and vice versa.
PilchY wrote:got my hnads on a LK202-24-USB - WB and i need to get a copy of the drivers to install the equipment so that LCD smartie can pick it up... anyone help me?
Hi PilchY,
Thanks for getting a LK292-24-USB-WB, the drivers are located in the hardware forum, under a stickied thread called USB DRIVERS!!!
http://www.lcdforums.com/forums/viewtopic.php?t=1016
If you have any problems, post there.
G78
two mx6 lcd screen vs software.
Post by G78 »
Just wondering, if i bought another mx6, and put it in the same pc... would i be able to program them both seperatly withought any problem with lcdc?
=G78=
G78,
You will just need to open up another LCDC. This will create another LCDC application. You will then set up the unit for the correct definition file and com port in the Configuration/test section. Test out the unit, and you should be good to go afterwards.
:D
G78
Post by G78 »
Ok, so 2 time LCDC software open..
One for each lcd screen...
How would it recognise each one seperatly, if it was two identical MX6?
Do they use a different coms port each?
=G78=
G78 wrote:Ok, so 2 time LCDC software open..
Yup, each MX will create its own virtual COM Port.
G78
Post by G78 »
thats another question.. how much ressources lcdc and MX6 takes to run smoothly... How would it run with two? Could there be bugs appearing having two running at the same time?
Like right now.. MX6+lcdc and the zephyrus kit... they really dont like each others.. Or the drivers for the zephyrus really sucks.
=G78=
G78,
When you open another LCDC, it will be opened as a seperate LCDC, and the icon will have a number over it to indicate the different LCDC applications. LCDC doesn't take much resources, but it will also depend on what plugins or amount of plugins the program is using. You would be able to find better answers to LCDC at the LCDC forum at http://forums.lcdc.cc/index.php?showforum=6
I have ran two LCDC applications, and I haven't had any problems with it though.
