PFiX Controls
Website: http://www.pfixcontrols.com/
Display Used: MOS-AL162A-BW3SE
Features: Pressure-based Tank Level Controller , also known as the Simplified Tank Level Controller, maintains the level of water in a tank between a Pump-on level and a Pump-off level. Operates completely from within the pump station. No equipment needed at the tank.
- pfixcontrols.gif (120.85 KiB) Viewed 81623 times
Germane Systems
Website: http://www.germanesys.com
Display Used: LCD0821
Features: Germane Systems has partnered with Spraycool, the industry leader in innovative, high performance electronic systems cooling. The main function of SprayCool Technology is to use evaporative cooling to keep processors (and other electronic components) in a thermally-controlled operating range,
- GS3400_large.jpg (17.67 KiB) Viewed 81622 times
- GS2700_large.jpg (12.58 KiB) Viewed 81622 times
- GS1360_AIO_large.jpg (23.97 KiB) Viewed 81622 times
Dantel Inc.
Website: http://www.dantel.com
Display Used: GLK19264-7T-1U-WB-E
Features: The WebMon Matrix is an intelligent, alarm monitoring and surveillance appliance that combines telemetric, transport and security capabilities into a single platform for operation in any network. The modular design of the Matrix provides an assortment of key capabilities and the flexibility to address any number of applications, delivering the right mix of features and capabilities for any job.
- Maxtrix-Web_M.jpg (6.1 KiB) Viewed 81619 times
Mu-Del Electronics
- mudel.JPG (12.61 KiB) Viewed 81717 times
S.two Corpotation
Website: http://www.stwo-corp.com
Display Used: GLK19264-7T-1U-USB-WB
Display Used: GLK24064-16-1U-TC
Features:
Features:
- stwo_TC.JPG (27.06 KiB) Viewed 75502 times
- stwo_TC_2.JPG (30.23 KiB) Viewed 75502 times
- stwo1.JPG (15.81 KiB) Viewed 81713 times
Telairity
Website: http://www.telairity.com
Features: The Telairity family of BE8000 and BE7000 series real-time encoders offer state-of-the-art AVC/H.264 video compression, low latency,
- Tel2.png (332.09 KiB) Viewed 71559 times
- GLK19264-7T-1U-WB
- telairity_1.JPG (17.26 KiB) Viewed 80848 times
Signature Machines
Website: http://www.signaturemachine.com
Features: The Ghostwriter T Series is our newest, smallest and most popular autopen. Weighing in at only 15 pounds and measuring just 18" X 18", the Ghostwriter is small enough to be placed on a table for convenient use or put on a shelf for easy storage. It's a workhorse machine that will sign all day long and never get writer
- signaturemachine.jpg (18.42 KiB) Viewed 80030 times
Technomad
Website: http://www.technomad.com
Display Used: LK162-12
Features: Automatic MP3 player/recorder with internal clock - ideal for themed entertainment, airport announcements, SFX, sports facilities, and more. 1500 minutes of internal storage, upgradable. Assign sounds to front knob and screen for instant playback, or assign sounds to a schedule you build for automatic playback. Networkable, remote control, knob lockout, more.
- The Schedulon
- schedulon_34.jpg (56.95 KiB) Viewed 80010 times
3SAE
Website: http://www.3sae.com/
Display Used: GLK19264-7T-1U-GW
Features: Large-diameter optical fibers are increasingly important in the development of new optical technologies. Cleaving these fibers for splicing presents many challenges. Low angle offsets and smooth, flat end faces are required. Many fibers are non-round or have internal structures that interfere with conventional cleaving. With some fibers priced in hundreds of dollars per meter, the length of cutoff scrap must be minimized. The 3SAE EndFace Prep Station meets these challenges with a novel, polishing-based design. The results are consistent, even for shaped fibers. The endfaces are flat and highly polished. The EPS is not an adapted connector polisher. The EPS is not an adapted connector polisher. The EPS is not an adapted connector polisher it is a purpose-built LD fiber preparation unit optimized for splicing applications.
- 3SAE_2.JPG (31.17 KiB) Viewed 75503 times
- 3SAE_3.JPG (26.99 KiB) Viewed 75503 times
- 3SAE_4.JPG (26.88 KiB) Viewed 75503 times
- 3SAE EndFace Prep Station
- EndFace Prep Station.PNG (248.82 KiB) Viewed 78634 times
Control Design Inc.
Website: http://www.cdione.com
Display Used: LK204-25-GW-E
Features: CD100 Wireless Controller Products Description
Control Design's CD100 Product line, first introduced in 1998 as the C18, DL810 and C44, is a highly integrated, programmable, wireless automation controller. It supports many customer-requested and field tested features for use in the Remote Control and Automation markets.
- HPIM2189.JPG (68.27 KiB) Viewed 73260 times
- HPIM2197.JPG (73.14 KiB) Viewed 73260 times
- DCP01116s.JPG (34.74 KiB) Viewed 78630 times
- DCP01088s.JPG (54.19 KiB) Viewed 78630 times
- DCP01174s.JPG (33.86 KiB) Viewed 78630 times
Siloam Biosciences
Website: http://www.siloambio.com
Display Used: LK204-7T-1U-YG
Features: Siloam Biosciences has developed a high-sensitivity platform for Point-of-Care Testing of clinically relevant analytes. The POCT platform is based on Siloam's proprietary "Smart" lab-on-a-chip technology.
- Chong Ahn, showing off his product
- 207973-0-0-3.jpg (44.42 KiB) Viewed 78626 times
- ivd.jpg (53.21 KiB) Viewed 78627 times
- ivd2.jpeg (23.27 KiB) Viewed 78627 times
One Digital Ltd.
Website: http://www.onedigital.ltd.uk
Display Used: LCD2041-GW
Features: The AIRLight is a brand new update to One Digital's established Audio Interview Recorder.
At almost half the weight and width of the classic AIR, the AIRLight has been re-engineered for true portability in response to customer demand.
Enhancements from the classic AIR include:
* Battery or mains power.
* Reduced power consumption.
* Clearer display.
* Bolt down option.
* Only 2.3kg
* Clearer display.
* Bolt down option.
* Only 2.3kg
- airlight.png (189.43 KiB) Viewed 78621 times
Microsonic Systems
Website: http://www.microsonics.com
Features: HENDRIX SM100 Programmable Ultrasonic Microplate Fluid Processor
- SM100.PNG (124.4 KiB) Viewed 78619 times
Pixon Imaging
Website: http://www.pixonimaging.com
Display Used: LK202-25-E
Features: PX50 Series image processors
Based on a powerful hardware combination of RISC processors and DSPs, combined with Pixon Imaging's proprietary and patented image-processing algorithms, the PX50 Series devices allow rapid, cost-effective adaptation to a variety of real-time image-processing applications.
- pixon.PNG (143.54 KiB) Viewed 78618 times
Instrulab
Website: http://www.instrulab.com
Display Used: GLK12232-25-SM
Features: Model 410 Handheld, RTD Temperature Monitor
- 410-1.JPG (54.41 KiB) Viewed 78616 times
