i just downloaded it and installed it again...line swapping is working fine here also....i was going to mention that the fade effect wasent working, but its working good now.....
cool...ive been playing with it for the last hour.....ive got the prog loading up upon startup...but is there a way to have it also start the display without haveing to bring up the prog and click the start/stop display button?
cool..i just discovered that actually....its a hit or miss thing with my system though.....the system does something with the com portsright after bootup... (if i dont load any lcd software, a few garbled characters will appear on the lcd) so for the first second or two, the port is not avalable and gives an error if the lcd software tries to load....this only happins every so often though (happins with other software also), usually the software loads right up....
maby you should have it delay a 2 seconds or so before loadup in case anyone else has this prob....(i think it might have to do with my audigy/live drive, as it never happined before it)
Help i install LCDC under Windows XP
When i start it he says : "Unable to locate Processor performance objet"
and when i trie to do something i lcdc say erroe on save
HEEEELLLLLLPPPPPP
My Processor is a PIV 1.80A
One more i have teste the borlndmm.dll with testdll.exe and it say :
fail ton find initialise in plug in borlndmm.dll, when i click on ok it say "error loading plug in" and i am in the test prg but evry where i have acces violation .....
