A Gallery of pictures...
Kwikmark
Website: http://www.kwikmark.com
Display Used: LK204-25-GW-V
Features: The kwikmark is the fastest dot peen marking system available. These machines were designed to be a cost-effective alternative to more expensive laser marking. At up to 20 characters per second no other impact marker comes close!
Tag Master 64.PNG (213.37 KiB) Viewed 99494 times
Tervela
Website: http://www.tervela.com
Display Used: GLK19264-7T-1U-WB
Features: Next-generation, enterprise-class messaging platforms used by data-intensive organizations for better competitive execution regardless of increasing volume, time sensitivity and global distribution requirements of business-critical information. Open. Intelligent. Extensible. And incredibly fast.
Tervela TMX-500
Tervela TMX-500
Website: http://www.evactron.com
Features: Evactron D-C cleaning uses a unique, cutting edge process for remote plasma production of oxygen radicals that flow downstream through your system, removing hydrocarbons.
Evactron 25 D-C
Evactron 25 D-C
Evactron45 D-C
Evactron45 D-C
NetGain Controls, Inc.
Website: http://www.ngcontrols.com
Display Used: LK204-7T-1U-WB-E
Features:
Somark Innovations
Website: http://www.somarkinnovations.com/
Display Used: MOS-AL162A-BW
Features: SOMARK is the creator of the Labstamp mouse ID system. Labstamp provides automated tail tattoos for mouse identification.
Thwing-Albert
Website: http://www.thwingalbert.com
Display Used: GLK24064-25-FGW
Features: The New FP-2255 COF Tester (Coefficient of friction tester) / Peel tester can be configured to measure the static and kinetic coefficient of friction, seal strength and peel properties of plastic film, paper, paperboard, adhesives, labels and packaging materials.
Ulyssix Technologies, Inc
Website: http://www.ulyssix.com
Display Used: GLK24064-25-WB
Features: The Gryphon100 Multiple Bit Synchronizer/Frame Synchronizer System is a fully integrated chassis solution that may be configured for two to four bit synchronizers and frame synchronizers with an internal IRIG time code reader. The Gryphon100 system utilizes the Ulyssix TarsusPCM-HS-02 Dual Bit Synchronizer/Frame Synchronizer w/ IRIG time code reader product which is a state-of-the-art Digital Signal Processing (DSP) based PCM processor. The chassis is a 2U rackmount system containing a large LCD graphic display and integrated keypad with the most advanced single board computer currently available on the market.
Gryphon100, GLK24064-25-WB
Feed Vision
Website: http://www.feedvision.com
Display Used: LK204-24-USB
Features: Mr. Tipster, keep up with the latest information you want and need: headline news, weather, sports, finances, blogs, eBay searches, and even custom data such as company production & job status, inventory and call levels.
LK204-24-USB
LK204-24-USB
Duma Video
Website: http://www.dumavideo.com
Features: Low Latency Encoding/Decoding Device
Put high quality video anywhere you want to with Duma Video's EVE compact video encoder/decoder appliance. EVE represents the latest in low latency digital encoding and decoding technology in a small, low power device suited for a wide range of digital video applications. Eve's advanced capabilities allow you to work with dual channel video to encode, decode, transcode and transrate video. EVE supports both SD and HD video resolutions up to 1080p/60. Encode your high resolution video output for broadcast and web resolutions simultaneously. Reduce frame rates for ultra low bandwidth broadcasts. EVE also encodes 4-channel stereo audio on MPEG layer 1 or 2, and can be upgraded to Dolby digital AC3.
LK204-7T-1U-WB, Duma Video
Intersense
Website: http://www.intersense.com
Display Used: BLK202A-BK
Features: IS-900 SimTracker Processor w/ MicroTrax Devices
BLK202A-BK, Intersense
Website: http://www.novawavetech.com
Features: NovaWave introduces the new TFL series tunable, single frequency UV-Vis fiber laser systems. The TFL family of fiber lasers comprises tunable, narrowband laser sources operating in the 106X nm, 53X nm, and 35X nm spectral regions, providing high purity, high power, TEM00 laser light with an associated frequency bandwidth of less than 0.01 cm-1. The lasers feature all polarization maintaining architectures with output powers up to approximately 0.8W and PER exceeding 20dB.
LK204-25-GW
LK204-25-GW
Blockwise Engineering
Website: http://www.blockwise.com
Features: Blockwise's catheter balloon wrappers offer unmatched accuracy and build quality. Whether you need to process a tiny PTCA or a 60mm diameter and 300mm long balloon we have a solution for you. Our products are grouped according to technology type of the pleat station:
LK204-25
LK204-25
Surfx
Website: http://www.surfxtechnologies.com
Features: Our company offers a full range of atmospheric plasma tools for treating microelectro-mechanical systems (MEMS), microfluidics, semiconductors, solar cells, medical devices, sensors, plastics and composites. Our atmospheric plasmas are cleanroom compatible, fast, safe and effective, and will not damage your critical parts.
GLK24064-25-FGW
GLK24064-25-FGW
HEKA Electronics
Website: http://www.heka.com
Display Used: LK162-12-GW
Features: HEKA is proud to introduce a manually controllable patch clamp amplifier with analog telegraphing outputs for Gain, Filter Bandwidth, Amplifier Mode and C-Slow. The EPC 800 USB allows third-party acquisition software (e.g. IGOR, Labview, pCLAMP) to read the status of these amplifier settings while recording data.
LK162-12-GW
LK162-12-GW
Website: http://www.picospin.com
Display Used: LCD0821-WB
Features: The picoSpin-45 proton NMR spectrometer is a true breakthrough in chemical instrumentation. Now you can afford a dedicated NMR spectrometer for your research, for your manufacturing process or for your classroom. Liquid samples are simply injected into an internal capillary via front-panel fittings, and only 20 microliters of sample fluid is needed to obtain a spectrum.
LCD0821-WB
LCD0821-WB
