LCDC
hey mat..a few more things for ya
i was setting it up to check my email....3 accounts...but it keeps clearing all the settings for the first account....and trying to set the check mail time to anything other than default 30 gives an error...
also, for what ever reason, it has switched lines 2 and 3 again...
Okay fixed nearly all the bugs pointed out here - and MBM plugin now has two events "On MBM temp >=" and "On mbm temp <" this makes it far better (I was trying to be clever and it didn't work as usual!)
I've removed the CPU performace for now as MBM can provide this anyway! ANd the net stats... well I just never got around to adding them! Lookout for a new version soon, however I'm holding on for a while. BTW suppurt for the GLK stuff is now much better as it uses "Flow Control" so the display is much better now, might even add hardware scroll to it!
having big probs using GLK12232-25-WBL with LCDC
first half of the first line seems to work fine - but then it goes boobies up after that. Anything on 1st line over the halfway point is wobbled around and muddled up after being written intially
2nd line writes ok and then jumps up to the mid point of the 1st line and messes things up more - looks fine on Virtual Display tho :/
any ideas?
any ideas?
Pretty sure this is a bug in the version onthe web... works fine in the latest versionOn 2002-03-17 16:16, Delta wrote:
any ideas?
r.
NEW VERSION 0.95beta 8
Is now available - this should let you use the GFX displays now (remember to download the chesefont and use that as it has blocks etc. setup for it)
I've added a whole bunch of new things:
GPO status in the virtual screen
On Key Pad press Group/screen action dependant (and global still)
New stats fully implemented
Fixed more bugs
Added a GPO toggle status
Page flipping (if your display is 20chars wide and you setup a 40wide one you can get it to display two different things, updates 1 per sec, if the second screen is blank then you can have flashing text)
Couple of new transitions
blah blah!!
Fixed more bugs
blah blah!!
The command [##254][##98][##2][##0][##0] will display the bitmap in pos. 2 at 0,0 in LCDC. If you add this to the definition file for you graphic, i.e. Draw = [##254][##98][##2][##0][##0] and then make an onstart event - process command - draw, you'll have what you want
r.
<font size=-1>[ This Message was edited by: TheCheeseMan on 2002-03-21 12:28 ]</font>
r.
Well that's not a built in feature... but you can do it If you look at the screen under Text each line can send a custom command, so you can set line two to place the graphic anywhere on line 1 (the command is run before the line) Now I've not had time to properly do anything on this but it should work. You'll need to enter the command yourself though e.g. [##254][##98][##1][##1][##1] - you'll need to work it out using the commands from the book, but that places gfx 1 at pos 1 1
