glk12232 GPO
tweak-freak
glk12232 GPO
Post by tweak-freak »
can someon explain how to hook up an led to the GPO
The load is where the led goes.....and since it output +5V when "off" then I need a resistor also correct?
linear
evil Dr. linear
evil Dr. linear
Post by linear »
LEDs are easy, just hook them right up. No additional components required.
LEDs are current-driven, so the limiting feature is desirable in this case, don't obsess about voltage.
The above assumes you're not using one of the 'high-power' GPOs on the newer units.
tweak-freak
well......how new.??? I prefer not to burn out my leds.... :-?
You will need a resistor when you use the GPOs on the GLk12232-25. About 470 Ohms should be good. So the way it will work is
PIN ---> Resitor ---> LED ---> Other PIN
tweak-freak
ok thx henry
