I can launch my display file manually, I have 'load at startup' up enabled, I have the display file selected, but LCDC won't start the display automatically. The program launches fine and goes to the tool tray. I had it working a long time ago on another system, but now it just does not seem to work.
Glenn
edited subject title.
Auto starting LCDC display at boot problems
-Glenn
AtechFabrication.com
LCDC will startup in whatever mode it is in when shut down. EG if you press "Start" then shutdown or EXIT LCDC, when you next start LCDC (or you PC) it will auto run.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
Please read me post again, I never mentioned about LCDC start, just talking about the start button status... which (I'll repeat) will be in the same state as it was when you shut down lcdc.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
