About to purchase a LK204-25PC
irajames1176
Post by irajames1176 »
I'm about to get one of the LK204-25PC's i was wondering what else i should get with it? do i need to purchase additional stuff with it or does it already come with everthing?
jodynicH
Case Guy
Case Guy
Post by jodynicH »
If you have one you may use a floppy cable, just like the one off you power supply for power, and you may want to purchase a serial cable as they are very thin and easy to hide and route. If you want to mount it in a drive bay get the double high black or white drive bay as well. Gluck!
The LCD (LK204-25-PC) only comes by it self.
As Jodynich said, a pcbay insert is a popular choice. If you get that, you get all the cables you need connect it. If mounting the LCD in the PC Bay insert is not your thing and want to make your own hole... try a mounting kit. MK2041 will be what you need, then you might want a serial cable and a power cable.
