2 pin probes?
thorilan
2 pin probes?
Post by thorilan »
i have temp sensors that only have 2 connectors . will i be able to use them on the MX213 ? if so which pins do i connect .
any help wouldbe greatly apriciated
Paradigm
Post by Paradigm »
I'm assuming that you have a temperature diode (only 2 pins). Unfortunately they require hardware to bias them properly and do analog to digital conversions. The MX series does not have the hardware to use them. If you want a list of hardware that is available for the 1-Wire bus see
http://www.maxim-ic.com/1-Wire.cfm
James McTavish, P.Eng
Director of Engineering
thorilan
Post by thorilan »
great .thank you very much . unfortunately it looks like if i cant find them localy here in japan ill have to order them and the shipping will cost more than buying 10 of them lol
We will be sleeing the temp probes in the next day or two, the cost will be $9.99 each and $some price if you buy 3 at a time...
calvin166
Post by calvin166 »
hey, i bought a mx 212 about 6 months ago. i was reading modthebox's reveiw and it seemed as thoguh you have redone the mx212. can i hook up the new led's and temp probes to my old mx212?
-Calvin166
"... and then..."
No...the new MX2 has been modified and improved upon both firmware and hardware wise...
calvin166
Post by calvin166 »
so neither the temp nor the leds.... that sucks :( is it possible you will mak ones for the old mx 212?
-Calvin166
"... and then..."
The one wire device is not supported with the old MX222 therefore there is no way we can make it compatible. As for the LED Indicator, the pin-out does not match up.
calvin166
Post by calvin166 »
darn... :( :cry: i wish it was possible :|
-Calvin166
"... and then..."
