4x20 RED USB vfd/lcd modul height below 5 cm
carlaron
Post by carlaron »
Hallo,
I am looking for a Display that can be connected to USB Port. I need a Display Sice of 4x20 and want it to be Red.
First question: As i want to use it in my car. Is vfd better with some filters to make it red? or should i use a lcd?
It needs to fit into some radio slot, which is about 5,5 cm in height. so as all your display-modules with 4x20 are around 6 cm, what can i do?
i have a HD44780 compatible coontroler. is it possible to get abare display to use with that?
this display looks great: LK204-24-USB-R
Thanks ahead.
Bernie
Post by Bernie »
Hello, your decision between the LCD or VFD displays will depend on your applicaton and/or personal preference. The VFD (vacuum Florecent) will have a much different look because of the technology used (better viewing angle, extended temp range etc.) compared to the LCD.
I do not have a suggestion/solution for your size constraint(5,5cm)....
Our display are HD44780 compatible but we only sell the serial interface board with display (packaged as one).
Regards,
Bernadine
carlaron
Post by carlaron »
I know that it is difficult.
The Display is to be used in a car.
VFD is more brilliant in that situtaton but lcd is still ok. first of all it has to fit.
i found the following manufacturer http://www.fordata.cn/ who has a display that might fit, only that i don't know where to get them.
do you have any ideas, or possibly ways to get one?
thanks ahead.
