VK202-25: Lifetime and power on command ?
Posted: Mon Aug 30, 2004 1:24 pm
by Mathieu_R
Two questions in the same topic:
- What is the lifetime of the VK202-25 display?
- Can I send the "Display On" command (254 66) very "often" (~100 times with 100ms between each) with no damage on the display?
Posted: Mon Aug 30, 2004 3:39 pm
by Tom
The life of the display is 20000 hours per half life of a display. You can send that command 100times without damaging the display.
Posted: Mon Aug 30, 2004 4:32 pm
by Delirious
Is the lifetime the same for the vk204-24?
Posted: Mon Aug 30, 2004 4:58 pm
by Miles
Yes, the lifetime is the same, however the thing you have to worry about with the VFD is burn in...
Posted: Mon Aug 30, 2004 5:14 pm
by Delirious
What is 'burn in' ?
Posted: Mon Aug 30, 2004 10:17 pm
by Tom
An example of burn in is when you leave your monitor on for awhile without a screensaver, and the image is burnt onto the screen. The VFD works the same way. It is healthy to clear your screen once in awhile if you have a VFD.
Posted: Tue Aug 31, 2004 8:20 am
by Delirious
So if i leave lcdc running is there any risk of burn in as long as its changeing the screen?
By clear the screen do u mean powering down the unit? Is there a way to power it down completely without unpluging it?
Posted: Tue Aug 31, 2004 9:46 am
by Tom
Your screen will be fine if you have the screen constantly moving with LCDC. What I meant by clearing the screen is clear any text or characters off the screen, not cycling the power.
Posted: Tue Aug 31, 2004 9:53 am
by Delirious
ah thx. Just out of curiosity is there a way to turn it off without unplugging it from the power source?
Posted: Tue Aug 31, 2004 10:13 am
by Tom
There is no way to turn off the power, unless you wire up a switch to the display.
