I need a display for a HTPC (placed in the living room). The display needs to be readable from a distance (2-3 m) and multiple angles.
I have read that VFD is generally easier to read than LCD, but the VFD displays from Matrix Orbital are very small (only 4,7 mm character height). An LCD display from C**********z has a character height of 7,3 mm, so I was wondering, which of these displays will be easiest to read? - I realise this may not be the best place to look for completely objective answers, but I don't know where else to ask...
Large LCD or small VFD?
Hi Thomp,
Thank you for posting.
The character VFDs and LCDs both use a 5x7 dot matrix font. If you want something brighter, go with the VFD. If you want something with bigger fonts, maybe you can think about use a graphics lcd, so you can upload your own size of fonts, but they won't be as bright.
Feel free to look at any of the manuals for more detailed information at http://www.matrixorbital.com/pages/manuals.asp.
Ok, now I'm a little confused
I checked the web-site specs and the pictures for VFD2041 and VK204-25, and I thought they were almost identical (same size, same color, almost same backlight strength). But when I read the specs in the manuals it seems like there are some major differences:
Visible display size: The VFD2041 is 6 mm larger (both vertical and horizontal) and the characters are larger as well.
Power usage (backlilght strength?): The VK has a typical usage of 220 mA, the VFD only uses 11 mA!
Color: The VK is Blue/green, the VFD is Yellow green.
The manual (VFD2041) also mentions some options which are not available in the shop (color options).
Which info is correct? Could you give me a (subjective) opinion on the look of the VFD2041 compared to the VK204 with regards to size, color and readability?
