Need more programming info
LCD user
Post by LCD user »
Can I program the MO434 to display several functions in succesion? For example; weather, then case temps, then download/upload speeds, and then something else. I want to be able to set it up and then leave it alone until I want to change it. Does it do this?
thanks.
Hi LCD user,
What you described is what LCDC does exactly for you. It will scroll from screen to screen until you stop the program or shut off the computer. Just set it, and forget it. For more detailed information on the MX434 display, you can refer to the manual at http://www.matrixorbital.ca/manuals/LK_ ... SB_100.pdf
For more information on LCDC, you can go to http://www.lcdc.cc/about.htm and the LCDC forum at http://forums.lcdc.cc/index.php?act=idx
