MX330 Display Issue
grueher
MX330 Display Issue
Post by grueher »
Hello everybody,
I am having a problem with my new MX330 VFD. It seems that every time I start up my computer the display works for about 20 minutes and then mysteriously shuts off until I completely turn off my system and turn it back on. It appears just restarting the machine won't revive the display. I am wondering if this is a USB problem or a problem with the VFD. Anybody else have this issue?
I have installed the new drivers and the display works well when it wants to. I appreciate any help on this subject, thank you.
- Christopher
Nick
Post by Nick »
grueher,
Thanks for posting! Have you checked your LCDC settings. There is an option for the display to time-out after so long. Let me know if that helps.
Nick
Nick Hesson
Sales Rep.
grueher
Post by grueher »
Nope, it seems to be something driver related - it turns off at a certain time after startup and it won't turn back on even if I fiddle with the LCDC settings and such. It won't even force a display. I've updated both drivers associated with the USB device, I am not sure if the USB controller from the motherboard has anything to do with it. I have an Asus A8N-SLI premium.
Any help would be much appreciated, thank you.
- Chris
Have you tried uninstalling and reinstalling the drivers and the registry entries?
The location of the registry entries is at
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\FTSER2K
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\FTDIBUS
Also do you have any conflicting drivers in device manager?
grueher
Post by grueher »
I've tried that twice now, and each time I start up the computer the display & LCDC starts up right and works well, then about 15~20min later it will shut off. There are no discrepencies with my hardware and everything is properly installed. I appreciate any other troubleshooting advice you can give, thank you.
- Chris
Hi grueher,
The backlight on for x minutes might be on for your MX330. You can try the following steps.
1) Downloading uproject http://www.matrixorbital.ca/software/so ... /uproject/
2) Execute uproject, and connect to your display.
3) Go to the remember tab, and there is a "remember" soft key. Click on it.
4) There are commands that you can turn on. Check on "Backlight on for 0 minutes" This will enable your backlight to be on all the time. When the backlight is turned off, it turns off the vfd.
Let me know how this works for you.
