2 Opteron temp displays = 2 LCDs?
I don't seem to be able to post in the seemingly more appropriate forum, keeps sending me back.
I would like please to know if I can have one Orbital display the CPU temperatures for 2 different processors (a pair of Opteron 252s) on the same display, or do I need to buy 2 units? Any advice or recommendations?
Thanks very much, I've looked everywhere, can't find the answer.
Shawn
Shawn
Hi shawn,
You don't need to use two different displays to monitor 2 processors. You monitor the cpus with two temperature probes or if the software permits it, you can use the software inconjunction with the LCD software LCDC. The mx series allows you to have more than 2 dallas one wire temperatures at once. For more detailed information on the MX series, you can refer to one of the manuals at http://www.matrixorbital.ca/manuals/LK_ ... USB_TM.pdf For information on LCDC, you can refer to the link at http://www.lcdc.cc/about.htm
Is it possible for one of the Orbitals to fit into 2 3.5" spaces? I'm having a heck of a time finding a case that I won't have to wait 4-6 weeks for delivery for. I can get a case that does what I need for drives, but then all that's available is 2 empty 3.5", i.e., Lian-Li PC-73.
Will an Orbital fit into that, 2 empty 3.5s?
Drives (6 empty hot swap external) and CPU monitoring is more important to me than the case...so I'd rather not buy this case if an Orbital won't fit into 2 3.5"ers.
Shawn
Shawn
OK I think I have figured everything out.
Now that I can put them in 2 bays, is it possible to have 2 exactly the same, except one prints red and one prints green, and both fit into the double bay black with buttons?
Just trying to narrow down my order. In other words, would this setup work, with 2 of these:
http://www.matrixorbital.com/product_in ... acter-lcds
- comps.jpg (78.3 KiB) Viewed 17031 times
Hi shawngibson,
Currently that set up won't work until the next release of the LK204-25. The LK204-25 will fit inside that mount, but the keypad won't connect properly. We have chaned it in the upcoming revision of the LK204-25. The display that will work for you will be the LK204-24-USB inside the mount shown at http://www.matrixorbital.com/product_in ... s-mounting
You may want to consider purchasing the unit as a MX4 series. I believe it might be less expensive to go that route, and you also get a lcdc key with it. The case you have for the display is a nice one. Your welcome to place your case inside our gallery after you are done with it.
Thanks Tom. I'm actually all set to order, so I'd like to see if I got you right. I don't really want the keypad, actually. I sort of made a mock order, and am I correct in this? I sent in an email, hope they know you've responded to me:)
LK204-25-IY
$82.95 USD
LK204-25-R
$82.95 USD
SERIAL CABLE -4BR
$10.78 USD
B2041-BK
$45.90 USD
If I am incorrect, for a 2-height non-key display, what is your total recommendation for me to purchase?
Shawn
LK204-25-IY
$82.95 USD
LK204-25-R
$82.95 USD
SERIAL CABLE -4BR
$10.78 USD
B2041-BK
$45.90 USD
Shawn
