Moderators: Henry , Mods
trance_Nation
Posts: 10 Joined: Tue May 23, 2006 9:55 am
Post
by trance_Nation » Wed May 24, 2006 11:03 am
I have a little problem. i have bought a new datacable and i have made my homemade poweadapter an when i test the display for the first time it workd fine. The startlogo came up. When i then tried LCDsmartie this came upp (Picture).
I have tried uProject but when i push for example Bar-graph the same thing happens. Does enyone know whats wrong?
Sorry for my bad english.
/Seabass
Img:
ghost2501
Posts: 59 Joined: Thu Aug 04, 2005 3:50 pm
Post
by ghost2501 » Wed May 24, 2006 11:09 am
best to just forget lcd smartie and those other programs LCDC does work with all the matrix orbital displays. I never had any luck with lcd smartie etc. I think they are junk really but thats just me. download a free 30 trial of LCDC to see if it suits you I amsure it will.
Jon
Posts: 231 Joined: Mon Oct 24, 2005 10:38 am
Post
by Jon » Wed May 24, 2006 11:14 am
What type of display are you using? Sometimes displays will act that way if you do not have the correct baud rate settings.
trance_Nation
Post
by trance_Nation » Wed May 24, 2006 11:32 am
i am using a LK204-25-WB
I tryed LCDC and when i run the quick startup guide it says that it dosent find the lcd :S but when i run lcdsmartie the funny text comes up
So it is connected.
Posts: 834 Joined: Thu Aug 19, 2004 3:37 pm
Post
by Raquel » Wed May 24, 2006 12:46 pm
Hi
The problem really sounds like wrong baud rate.
Is it possible for you to post a picture of your LK204-25? I want to see what settings you have on the module.
Posts: 1030 Joined: Mon Jul 19, 2004 4:43 pm
Post
by Tom » Wed May 24, 2006 1:24 pm
Can you get closer to the middle, right above the serial connector?
trance_Nation
Post
by trance_Nation » Wed May 24, 2006 1:33 pm
Sure.
it may be impossible to read in the pic but it says:
SIPEX
SP232AEN
0243
The last image is the littel piece of paper that was glued to one of thoes littel black spots.
heres a pic:
Post
by Raquel » Wed May 24, 2006 1:55 pm
Hi
Your board is set at TTL levels. The first picture in your last post where it says 'it may be impossible to read in the pic but it says:
SIPEX
SP232AEN
0243 '
have two pads jumpered/soldered. You need to take those solder jumps off.
Raquel on Wed May 24, 2006 1:57 pm, edited 1 time in total.
trance_Nation
Post
by trance_Nation » Wed May 24, 2006 1:56 pm
Okay, and where can i find thoes?
Edit: Oh i think i see them is it safe to solder them off? Im right sure i cant get them back if i take em off :O
Edit again: Or is it just umm metal? Not an component?
Post
by Raquel » Wed May 24, 2006 2:07 pm
Yes, you can solder/wick them off, those are components, just solder blobs.
I was told there is more to this, Tom will be posting the details and a picture of what your board should look like to completely put it in RS232.
Post
by Tom » Wed May 24, 2006 2:28 pm
Here is a picture to illustrate what you should do to convert the unit back to RS-232.
RS-232 LK204-25backslbl.JPG (43.05 KiB) Viewed 21799 times
trance_Nation
Post
by trance_Nation » Wed May 24, 2006 3:10 pm
Thanx that really helped!
Shall i change "RS-232 Speed and I2C settings"? or shall i leave it in the middle?
What baudrate shall i use? 192Somthingsomthing?
Post
by Raquel » Wed May 24, 2006 3:19 pm
Leave the 2 jumpers in the middle. Set LCDC to 19200 baud.
trance_Nation
Post
by trance_Nation » Wed May 24, 2006 3:29 pm
thanx for the help!
Hope i will become as smart as you guys
Cheers!
/sebbe
