Double bay for LK204-25-V
B2041
Thats what you need...
http://www.matrixorbital.com/products/b2041.htm
theres the page for you, good luck!
B2041 will do the trick I think... comes with a wide voltage modded power cable (which is what the -v needs) and a normal serial cable, N.B. no pci slot cover thingie.
The slot pass through only comes on the 4BR cable (which is just a different shaped serial plug on the display)...
r.
r.
