good day!
can you please help me?
im a proud owner of a mx212..
but there seems to be a problem with it.
at first,i did everything that the quick install guide said, and it did work fine.
i played around with it, spend less than an hour with it.
then i decided to restart the computer..
after that, after the pc booted to windows xp, the mx212 didnt power up (blank screen). then, a pop up appeared saying new device found, then after that, it was saying that it cant be recognized =c i looked at the device manager and the mx was gone and the unknown device was there...
i dont know what happened
MX212 Problem
Hi Wushuvushu,
Please give me an email at jklassen@matrixorbital.ca and I will try to work with you to resolve the problem. At this point I can recommend re-installing the drivers, as well as trying a different USB port. I look forward to hearing from you.
Jon
Jon
Hello Again,
V1.4 is the latest WinXP driver which can be found here:
http://www.matrixorbital.ca/drivers/
Jon
Jon
