Can't Identify Model of LCD in 2nd hand case. Need help
Sorry, but a friend of mine gave me his old case with a MO lcd. Because he left it unused for so long he forgot the model and no longer has anysoftware for it. This particular unit is 20 char x 4 lines and connects via the serial port. I downloaded uProject, but it doesn't seem to detect the unit. However, when it does run run the autodetect, the lcd outputs strange characters (X with a line over it, a right arrow, and another character i don't recognize). any clue?
Thanks for the reply.
I ran through all the baud rates on either COM in uProject and it never found the display with the auto detect. I was able to simply set it to the right com port and baud rate and it connected.
When I took pictures of the unit i noticed the model number myself finally. Could you tell me if there any specific drivers or utilities I should have for it. I would like to know how to set it up in order to display various sorts of system information.
- tech support 1.jpg (65.18 KiB) Viewed 3847 times
Hello Simpsonrb,
Glad that you are able to connect to your LCD2041 module. Here's the link to the manual:
http://www.matrixorbital.ca/manuals/LCD ... 41_150.pdf
Also, I assume that you do not have LCDC (software that usually comes with the module). You will probably have to get one:
http://lcdc.planetdps.com/
