Update!!!
Update!!!
Just to let you all know, the PC Bay inserts have arrived and we are doing some final Firmware changes and expect everything to ship tomorrow or day after!!!
- Stolen from the LCDStudio forums ;)
- GX_SAL9000_04.JPG (58.87 KiB) Viewed 20623 times
- GX under MCE
- GX_SAL9000_03.JPG (55.18 KiB) Viewed 20624 times
- GX_SAL9000_02.JPG (57.92 KiB) Viewed 20627 times
- GX Typhoon and SAL-9000
- GX_SAL9000_01.JPG (61.87 KiB) Viewed 20628 times
- LCD!
non updates..
Yes, a couple of time lines have gone by with no updates...alentsa wrote:No wonder, we all want more news in this "Update!!!" thread!
Larger Typhoon - where is it?
Std Typhoon with no IR port - where is it?
They don't seem to keep the website quite up to date which kind of makes me concerned about purchasing something. I'm still about a month away before I'll need to purchase a display... perhaps we'll have an update by then?
updates..
Wasn't too worried about the IR port interface causing conflicts, just don't need it at all so it ends up just taking space and making the display "off center" for my use.
I still have another month to wait before I'll need it, so hopefully we'll see those pesky updates by then. I'm really hoping they come through as of all the other display mfr's I've looked at, this GX looks the best.
It is being worked on, currently we aim for a Q4'07 Release. The 240x128 model will not come with a PC bayLarger Typhoon - where is it?
All Typhoons will come with an IR port, there is a firmware+software update planned that allows you to disable it on te GX side so windows will not detect it.Std Typhoon with no IR port - where is it?
My old C**********z display was made as a small bracket, allowing me to mount an extra hard drive in same bay. The standard GX insert takes the whole bay. It has a few extra threaded mounting holes, but I can't use them for anything (they don't seem to fit a standard 3.5" drive), so the entire bay is taken by the display. I would suggest to change your design and let us use the bay space more economically.
I'm ok with the larger display having no PC Bay... was planning on mounting it on the "front door" on my chassis. May wait for that, but just depends on if Q4 means Oct... or Dec.Ray wrote:It is being worked on, currently we aim for a Q4'07 Release. The 240x128 model will not come with a PC bayLarger Typhoon - where is it?All Typhoons will come with an IR port, there is a firmware+software update planned that allows you to disable it on te GX side so windows will not detect it.Std Typhoon with no IR port - where is it?
May go with smaller one.. saw a reply from Henry regarding the I/O port that made me question when it was going to be released.
Originally posted by creepyarcade
I have 2 questions:
1. Will this unit be available without the IR control on the faceplate? I would like to attach the IR Receiver someplace else instead.
Yes, but not for a few weeks.
But what you say may contradict that?? Or will the space always be taken up by the panel, but maybe a removable IR receiver made available?
Thanx!
GX
I have 2 questions:
Thanx!
GX
I have 2 questions:
Thanx!
