If, for some reason, MO doesn't want these pics up, that is up to them.
I find it a bit odd they don't have a User manual or anything up yet, but for those interested, here are some Macros of the Typhoon "naked"
GX Typhoon Closeup pics removed from Mounting Bracket-56K+
- LCD Geek
Re: GX Typhoon Closeup pics removed from Mounting Bracket-56
Awesome! Thanks for spending time to take these pics.
It will let me know what mine will look like, as I just ordered a GX with the white pixels and blue background. It looked to be a bit easier to read (and unique) compared to the standard LCDs with black (pseudo-black).
Are your photos of the tri-color background GX or white/blue GX?
My blog: http://2geek.org
nope, when I tried the Mini 5pin, it worked just perfectly, and using a leftover cable and crimping the motherboard end was a lot easier to test than soldering the 4pins onto the MO unit.
However, the solder points look empty, so putting a pin in there should be easy unless it could short anything on the inside.
I didn't separate the two PCBs, so I don't know if there is a chance of shorting out the guts.
Regular 4 wire USB to motherboard works perfectly, so I'm not complaining.
