OK, so trying to get a Typhoon to work on Vista 64.
Following the instructions as posted here - http://www.lcdforums.com/forums/viewtopic.php?t=3763
1 - Driver Core = Dead link! Great start!
2 - LCD Studio = Fine, installed it, but no good without (1) I assume.
3 - .Net 2.0 = I assume you do not need to do this with Vista 64 SP1?
Would be nice to be able to use the typhoon
OK, how do I get the Typhoon to work? Bad instructions!
Actually with your GX you should have gotten a letter with the correct location of the Drivers. If this wasn't included please let me know.
The latest drivers you can find here the current latest verison of the drivers are the Aug 2008 software pack for the GX
Ps. no need to cross post, its a relativly small forum, I do read all of it
Try some of the links in your own sticky - http://www.lcdforums.com/forums/viewtopic.php?t=3763Ray wrote:Actually with your GX you should have gotten a letter with the correct location of the Drivers. If this wasn't included please let me know.
I have created a signed version of LcdStudio 806 (same version as in the aug'08 rev1 software pack) just copy the exe file over the old copy (no installation required) and see if that makes defender happy. Please report back any success or failure
OK! Thanks! Will give it a go and let you know...Ray wrote:I have created a signed version of LcdStudio 806 (same version as in the aug'08 rev1 software pack) just copy the exe file over the old copy (no installation required) and see if that makes defender happy. Please report back any success or failure
Still fails I'm afraid! Windows Defender refuses to run it at startup.NeilF wrote:OK! Thanks! Will give it a go and let you know...Ray wrote:I have created a signed version of LcdStudio 806 (same version as in the aug'08 rev1 software pack) just copy the exe file over the old copy (no installation required) and see if that makes defender happy. Please report back any success or failure
