x-board where to buy?
ghost2501
Post by ghost2501 »
Hello I cant seem to find the x-board on your website. Are there different kinds? I have a 4x20 oled display that is standard hd47780 I believe. What can I do with this can I use an x-board to hook up to it and make it usb? I would then like to use lcdc with it as this is the only program I know how to use.
I have several mx series and a few others.
where can i buy the x-boards and am I on the right track as far as what I can do with it?
The Xboard comes in 3 flavours:
Xboard S (UART)
Xboard I (I2C)
Xboard U (USB)
You should be able to interface with the OLED display you have, provided that it does use a standard HD47780 or compatible controller, and is capable of 4 pin parallel interface.
You can find the Xboard here.
I hope this helps.
Thanks and Best Regards,
