I just received a GX24064 USB display. I installed the drivers and LCDStudio and all that works great.
However, I want to write my own program to control the display via python. I'm having no luck finding the virtual COM port the drivers are supposed to give me.
Communication with the display seems fine, since LCDStudio works. In the Device Manager, I have an entry for the Matrix Orbital GX Series rev 2 display, but under the Ports (COM & LPT) I have only the built-in "real" serial ports COM1 and COM2.
Any ideas? is there another driver I should have installed? Thanks!
-Doug
Can't find serial port for USB GX24064
The GX doesn't use the regular ftdi usb-> serial chips we use on many of our other products the speeds we where able to acchive using the usb-> serial chips where not up to par with the peformance we wanted.
For writing your custom application we do supply a library you can use from any .Net language, see this topic for a walkthough + small code sample. I'm not entirely sure how well python deals with .net stuff though.
