Would I be able to connect the power through the 4 pin headers
Yes, this is how you power the display. Please see page 6 of the
manual regarding the 4 pin connector (marked #5).
And for serial transfers, I'm not using the 4 pin header but using the RS232 port on the back of the LCD to a serial port on my ATMega development board STK500.
Yes, you can just use the 4 pin connector for power and gnd, and use the DB9 for RS232 communication, but please make sure you use a NULL serial cable to connect your STK500 to the display.
Also, reading the troubleshooting area in the LCD manual for no text being shown. It mentions about uploading fonts onto the LCD, are defaults font already on the board?
There should be 2 fonts pre-uploaded on the display.
For now, I will get you to do the following:
1. Make sure that the display is still on RS232 mode.
2. On your PC, open up Hyperterminal, 19200, 8 bits, no parity, 1 stop bit, no flow control
3. Power the display using the 4 pin connector.
4. Connect the display to the PC using a straight thru serial cable.
5. Start typing on hyperterminal and you should see the characters on the display.
Let me know how it turns out. We can then move on to connecting to the STK500 when you have successfully done the suggested steps above.
