Hi is there a way to reinstall firmware , cause i have 2 of these PCB rev 2.0 , one test perfectely with uProject and the other one not !!! it has problem with communication i must put the manual jumper all the time to have minimal communication and then most of text send to the display is corrupted !!!!
VFD2041 Firmware ??
Hi Mindstorm,
Unfortunately, we do not make a habit of publishing our firmware, but we do offer the manual override function to temporarily restore all settings. In override mode, I would recommend saving the baud rate to 19200 to ease your communication trouble. You may also investigate the hardware to ensure there is not a loose connection to your display.
