getting response for the regions not defined
pradipsangani
Post by pradipsangani »
I am sometimes getting responses for regions which are not defined as touch regions. Even for the defined touch regions, i am getting wrong responses some times. Can you please help me on this.
I have also attached the script file for the program loaded on touchscreen.
load_individual_bitmaps_to_buffres.gsf
(2.85 KiB) Downloaded 482 times
Pads
Hi Pads,
I appreciate the code provided, if you could please also grab the images, firmware revision of your unit, and any other tips that might cause the problem to occer I can try to replicate the issue here. Please send those directly to me at tclark@matrixorbital.ca.
